I have a centrios dvd recorder, I love it! My question is how do you record dvd to dvdrecorder with a DVD movie I bought? Or is this possible? When I try I get recording prohibited. I know its the copyright protection on the dvd. I hooked it straight up using the RCA jacks. Is there a way to fool this? Or am I just stuck using my computer to back up my dvd's? Thanks for anyones input or advise!
To fix that problem I went out and got an Apex AD-600A dvd player off of Ebay. That particular model from around 1999-2000 had a "secret loopholes menu" which allows you to turn the macrovision (copyguard) off in order to back up your movies. It works great! That was my simple solution.
Yep, i use a cyberhome and GE that are hacked for the loopholes to change region and turn of macrovision ect. for doing such things, you can get a cyberhome for $40.00 & under.
But that is for extreme cases as i would think most would want to do the backup on their pc as to render much better quality -
Turning off macrovision will not stop the can't copy message,that's caused by Digital Copy Protection not macrovision. The Ad-600A will turn off macrovision but I think you need the OFFA firmware to turnoff DCP. Some DVD turnoff macrovision but not DCP. Be careful they are two different things.
This device works well for DVDR to DVDR or VHS to DVDR.
http://www.facetvideo.com/xcart/customer/product.php?productid=83&cat=26&page=1
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
