I have an experience to make, I don't know if it has happened to me or if you know the reason.
i tried to capture some vhs and i tried to do it using virtualbub. I was tired and went to lie in bed; i launched the capture and then forgot it and i fell asleep.
the next day, it was impossible for me to boot the computer; it crashed upon reading the disk and sometimes the bios didn't even detected the disk.. even tring to access it by partition magic didn't make it, errors..
i solved the program by rewritting the master boot record with the hard drivers manufacturers utility, the one that also low formats and reinstall windows.. now I don't dare to send a cap in virtualdub .
what do you think it might have happened?
hard drive failed or got corrupted - unlikely it is virtualdubs fault
may of overheated on a long capture -- seen it"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Overheating on capping - been there and shed the tears
. Keep an eye on processor usage in Virtualdub to see what it is doing , the hard drive working flat out to save the cap will be belting out the heat as well .
I used to keep the side cover of my pc off when capping for a long spell , had to defluff the case more often but it worked , obviously better cooling will do the trick even better ... but sometimes I can`t be arsed
AutoGK keeps screwing up my resolution.
By mob in forum DVD RippingReplies: 5Last Post: 30th Aug 2010, 07:34 -
Removing VirtualDub from Computer
By Sidus1 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2010, 17:04 -
Magix is screwing with me and keeping my money!
By Des in forum Newbie / General discussionsReplies: 43Last Post: 2nd Oct 2009, 21:12 -
re: Labeling screwing up DVD-Rs
By okyup in forum MediaReplies: 21Last Post: 6th Jan 2009, 03:21 -
xvid videos screwing up
By mds88 in forum Newbie / General discussionsReplies: 6Last Post: 25th Oct 2007, 10:16
