I'm using Nero 6.6 and I have never updated it because it seems to work fine. If I was to install the updates, do you recommend that I uninstall the old version first?
I'm curious because when I updated Adobe Reader 6.02 to version 7.0 by simply running the version 7.0 .exe file, it installed without uninstalling the previous version i.e. it deleted the old shortcuts and the 6.02 uninstaller from Windows "Add/Remove Programs" utility but heaps of 6.02 was left behind in Program Folders and registries.
I like to keep my Win XP clean, your suggestions is appreciated. Thanks.
Just download from the update page and install, that's all I do - http://www.nero.com/us/nero-up.php
Make sure you downloaded the entire file by using their MD5 Verifier - http://www.nero.com/us/Nero_MD5_Verifier.html -
Adobe has always been like that. For most programs you just download and install the update(s) as HatchetMan suggested.
Google is your Friend
Nero 6 vs Xp updates Mid July 2009 , NO DISC DETECTED
By org74 in forum DVD RippingReplies: 0Last Post: 1st Aug 2009, 14:35 -
AVG 8 updates?
By wulf109 in forum ComputerReplies: 2Last Post: 3rd Feb 2009, 10:49 -
M2TS files have started playing slow after installing Nero.
By inano in forum Blu-ray RippingReplies: 7Last Post: 8th Dec 2008, 21:03 -
strange updates
By Tom in HD in forum MacReplies: 1Last Post: 19th Feb 2008, 21:29 -
Problem Installing Nero 8
By ranchhand in forum ComputerReplies: 1Last Post: 10th Feb 2008, 22:20
