I am tring to back up the movie Hitched with DVD shrink and it gets about 13% of the way on the encoding process and then gives me a copy protection error. Has anyone else had this problem or know a way around it?
Try using the latest version of DVDDecrypter and ripping to file mode. Select this file with Shrink, then proceed as usual. Also check Shrink's version and see if there may be a newer one that addresses this.
No. DVDdecrypter only rips. It is a 1:1 quality. If it is still to big, then yiou shrink it in DVDshrink and thats when you can loose quality. Unless you do a movie only copy and it happens to be less than a DVD-5 it will require compression. Otherwise no
No DVD can withstand the power of DVDShrink along with AnyDVD! -
So there aren't any settings to change in DVDDecryptor I just select the source and the fold to put the files in and then open the folder in DVD Shrink?
Blu-ray Back -up Problem
By tryst1 in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Oct 2010, 16:34 -
back up dvd problem
By ecos in forum Newbie / General discussionsReplies: 3Last Post: 25th Feb 2009, 12:43 -
Interlacing problem with back-up of a dvd
By bgart13 in forum Newbie / General discussionsReplies: 16Last Post: 9th Apr 2008, 13:31 -
Laptop Problem: Does not always turn back on...
By Super Warrior in forum ComputerReplies: 10Last Post: 16th Feb 2008, 06:19 -
Play back problem with audio pitch
By Silverknight in forum AudioReplies: 3Last Post: 6th Aug 2007, 23:03
