Results 1 to 27 of 27
  1. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Hi B & mods,
    Just had a thought - would a mini-guide describing how to take and upload screenshots in the forums be a useful addition to the site ?
    Maybe a sticky in Newbie / General or something ?
    Just getting a bit tired of having to recompose the instructions on how to every time someone asks, is all ...
    ... and it's easier to find /refer to if it's sitting at the top of a forum
    Thoughts ?
    If in doubt, Google it.
    May 2001
    If they're not going to read:
    "Type {img]filename.gif[/img} in your post where the image should be. JPG, GIF and PNG are the allowed formats and the max file size is 150 KB.",
    then what makes you think that they will take the time to read a sticky?
    But still, it may be worth the effort. So get writing!
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I don't think noobs will read it of their own accord either - it will just be easier for me to find it to refer it to them !
    Nov 2003
    Ontario, Canada
    FWIW, I think it's a good idea, Jim.
  5. If you write it and post it, I will make it a sticky!
    There are 10 kinds of people in this world. Those that understand binary...
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    No, I will make it a sticky!
  7. There are 10 kinds of people in this world. Those that understand binary...
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    if they can not read that one simple line - you think they will read a sticky ?
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    As I said (and as we've debated in the past), I don't think a lot of NOOBs will read it of their own accord - as we say, if they don't read that one line then they won't read it. IMO if it's sitting at the top of a forum, or in the guides section, then at least SOME go-getters will discover it on their own, and for those who don't, I can tell them to RTFM !
    Also, at least it makes it easy for me or someone to locate it to refer to them if it's sitting at the top, instead of having to dig or search for it too intensely.
    Thanks to B and b for the vote of support - working on it ATM .....
  10. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Looks like jimmalenko has finished. Time to ask a mod to get it stickied
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Nah, not finished yet .... I'm just resting.
    I'll do the asking when I'm happy with it
  12. see waiting for that guide.
    realy...You can only upload 1 at a time right?
  13. Член BJ_M's Avatar
    Jul 2002
    Canada
    you would think he is painting the whitehouse red
  14. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    christ ..... the natives are restless ...
  15. You would never see a whitehouse up here,to much SNOW..Maybe a red roof...
  16. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The guide is a work in progress ATM ...
    https://www.videohelp.com/forum/viewtopic.php?t=271697
  17. Nice guide....
    To much work..... I need somthing easier...
    Nice work Jim...
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    we like a guide like this:
    1. point
    2. click
    3. go to step 1.
  19. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    1. point
    2. click
    3. go to step 1.
    OK then. Short guide:
    1. press PRINT SCR for whole screen or ALT + PRINT SCR for Object selection.
    2. paste into paint and save
    3. upload to videohelp.
  20. Член BJ_M's Avatar
    Jul 2002
    Canada
    very good - excellent
    we will make it a sticky and also mass email and post it on google, make it a pop up and a browser bar ..
    put it on the page feed also
  21. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    1. point
    2. click
    3. go to step 1.
    Like they are gonna figure that out when they can't even figure out how to post a pic in the post
    Hurry up and finish it canadateck is waiting :P
  22. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Bump ...
    The "guide" is currently residing here, and has been completed to my satisfaction, so could someone please move the post to Newbie / General, sticky it, and blow away the posts from the cretins that replied to it while it was a work in progress ...
    Thanks.
  23. Originally Posted by Jim
    https://www.videohelp.com/forum/viewtopic.php?p=1322414
    Your wish is my command. You're right at the top of the sticky list for now!
    Thanks.
    No, thank you. We've needed a comprehensive guide like this for quite some time!
  24. Oh, one thing! In Paint, why not add in that you can get rid of the white bits by looking for those little adjustment squares on the edge of the white border (you know what I'm on about, right?) and moving them in. I notice you have them in one picture but must have removed them by the time you came to open it in PSP.
  25. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Good idea, snake dude
    TBH I only use PSP, so the Windows Paint section was a bit rough n ready, but good enough to get the job done. When you import into PSP, it doesn't have those white bars so I never really thought about it. I contemplated going into cropping and stuff like that but I thought it was probably getting a bit too advanced, given the purpose and scope of the guide.
    I'm happy to add that addendum in though, but I noticed you've locked the thread. I don't mind if there's replies to it, so could you unlock it ? At least then I can edit the OP if required with any further problems, maybe a photoshop section (if someone's willing to do it for me), etc etc ...
    Thoughts ?
  26. Unlocked. I forgot that by locking it I locked you out of editing your own post - sorry about that!
  27. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    no worries.
    Thanks mate
