materials i have on hand:
1 x a project file (.D2V)
2 x different language audio streams (.WAV)
using tmpgenc i can only create a mpg with only one of the streams (i.e. able to select one of the WAVs only)
anyhelp on encoding a mpg with both streams? i think i saw a relevant link a long time ago somewhere in the How-Tos.. cant find it now.. a search on the forums didnt turn up what i was looking for (could be my fault)
thanks alot
The easist/simpliest thing to do is to make a (x)SVCD. MPEG2 supports mulitple audio tracks. All you need to do is use TMPGenc to encode the D2V -> M2V (video only) and each wav -> MP2 (audio only). Then use bbMPEG to mux video.m2v + audio1.mp2 + audio2.mp2 -> MPG
You can switch audio tracks by hitting the audio button on your remote.
If you want to make a (x)VCD, then you need to put one track on the left channel and the other on the right (as MPEG1 doesn't support multiple audio tracks). Cooledit can do this. You can d/load a crippleware verison from http://www.download.com The demo only allows you to use 3 features at once, so just choose the ones you need. -
thx i figured out the channels thing after deeper searching thru the wealth of information in this forum :>
anyways thx for ur reply.. noticed u r a frequent replier to subjects on these audio channel stuff hehe
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 04:31 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
VCD Dual-Audio to AVI
By amadeira in forum Video ConversionReplies: 10Last Post: 12th Oct 2008, 11:10
