    Dec 2004
    wales uk
    i downloaded two media files and incorrectly named 1 of them .wmf wheras it plays in all media players, unlike the other which i named .wmv
    i cannot edit it in nero windows movie maker etc, is there any tool programme to convert the incorrectly named .wmf file?
    any help would be highly appreciated.
    joe sheehan
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Rename it to .wmv, perhaps ?
    If in doubt, Google it.
    USA
    And if you don't know; In 'Folder Options', make sure you uncheck 'Hide extensions for known file types' if you want to see and change the extensions.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Go to My Computer > Tools > Folder Options > View:
    Untick this box and you should be able to see file extensions. Then just click on the file and press F2, or right-click on it and go to Rename, or click once, wait a second or two, then click again and you should be able to rename the file.
    Dec 2004
    wales uk
    That is so very, very helpfull of you all I am delighted. Yesterday i called a comp helpline £1 every 30 seconds after £25 i gave up you have solved it for me and with style, I am so gratefull
    what a great site this is!
    joe sheehan
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That'll be £25, please
    Dec 2004
    wales uk
    advance Australia fair
    i promise I'll make a donation to charity
    thanks ever so much again
    joe sheehan
