hi, i have a 700mb avi file and would like to reduce that to 300mb (AVI to VCD). is that even possible without losing its quality? if so, what is the best software that does the trick? your input will be highly appreciated. thanks!
How many minutes? The avi file size does not matter if you convert to MPEG1 VCD.
VCD is around 10MB/minute and you can't change that. You can make a "XVCD" and lower the bitrate and get smaller file size. -
A common 700 MB AVI, if it's DivX or similar, usually is >= 1 hour, so as VCD it'll be >=600 MB. And encoding to VCD (or anything else, but VCD in particular) will reduce the quality.
/Mats -
thank you so much for your replies. i'm still trying to get used to these technical terms..
but i really appreciate it.
Hi, ione.
The '.avi' is an extension to indicate the container of the raw movie data. A container is needed because, for one thing, it holds the audio and video together and keeps them from walking away from each other. Other such containers are: .mkv and .mp4.
To reduce the file-size of a movie from 700 MB to 300 MB needs compression. So if your .avi already contains a compressed stream (e.g., DivX or XviD compression), then you will lose quality because fresh encoding will be required. Encoding almost always sacrifices quality.
Several transcoders are available. One that will do mpeg4>mpeg1 conversion will do for you if your .avi is mpeg4 (i.e., DivX or XviD).
Thanks. -
What will you be playing the final product on?
tool to create 300mb x264 mkv movies
By lordrt in forum Video ConversionReplies: 2Last Post: 17th Jun 2010, 13:45 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 21:55 -
GOTSent breaks the MKV file after 300MB
By zilbermm in forum Video ConversionReplies: 1Last Post: 5th Apr 2009, 04:31 -
700MB before subs, 1.12GB after??
By tommy23 in forum SubtitleReplies: 6Last Post: 17th Oct 2007, 23:05 -
cannot make 700mb rips
By zakkwyldebls in forum DVD RippingReplies: 6Last Post: 9th May 2007, 23:43
