I recently captured several vhs tapes using a hardware based mpeg capture device. They came out pretty good. However, there are sections I would like to clean up using video noise filters, as an example. The question I have is...
Is it better to run the mpeg through a program like TempgEnc utilizing their filters on the mpeg as is? Or is it better to convert the file to some less compressed AVI format, and THEN run IT through some filters?
I personally don't have a clue.
What do you want to do with the video in the end? If you want it as mpg (for DVD/SVCD/VCD), you'd better not take the route over AVI (at least not any compressed AVI).
/Mats -
It doesn't really matter. Whatever program you use to filter with, it will decode the soure file to raw frames, apply the filters to that and then (possibly) re-encode the filtered frames back to whatever format you select. So you will be re-encoding at least once. So converting to uncompressed avi has no benefit and converting to some other compressed format just introduces an extra re-encode, which is something to be avoided if at all possible
There are 10 kinds of people in this world. Those that understand binary... -
Originally Posted by bugster
/Mats
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
Cleaning up a concatenated MPEG-2
By thinker3932 in forum Video ConversionReplies: 22Last Post: 25th Aug 2008, 20:37 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33 -
1st time on linux: looking to convert my DVDs to x264
By bgbop15 in forum LinuxReplies: 3Last Post: 19th Jul 2007, 13:56 -
VHS to DVD with Canopus ADVC110 - mostly filter/cleaning questions
By Z-C in forum RestorationReplies: 121Last Post: 14th Jun 2007, 05:55
