ok, i have a avi video file and a .ssa subtitle file. how do i back the avi file up with the subtitle? TY ahead of time
Results 1 to 9 of 9
It's very unclear what you want to do - Just back them up? In that case, just copy them to another place on your HDD, or burn them as data to a recordable CD or DVD.
But perhaps you want to convert them into something watchable using a DVD player? In that case, head over to the convert section, search under AVI to DVD. Or am I completely at the wrong track?
/Mats -
No your right (ther are 3 avi video files and 3 subtitles), i want to watch them on my dvd, create menu, chapters and stuff. how do i back them all up as a dvd with the subtitles? i have dvd lad pro but dont know how to use it yet. will this work with avi's? or is it a easier way to do what i want to do? TY
You will need to get a DVD authoring program that accepts subtitles, of which DVD Lab Pro is an example.
Convert your AVI and audio to DVD compliant streams, import the audio video and subtitle streams into DVD lab, build project, compile, burn.
Guides for all these procedures can be found on this site. -
...or if you want a free solution, DVDAuthorGUI, GUI for DVDAuthor, IfoEdit are options.
/Mats -
ok, i went to dvd lab pro and i tried to open the avi file but it wont open. and i doing something wrong or does it not open avi files.? i went to a dvd lab pro tutorial but cant find the answer to my problem. if i convert my 230 mb avi to mpeg, its becomes huge. any other ways? i tried using vdubmod to seperate the audio and video but it wont work for me.
dvd lab pro won't open AVI files - you need to convert to DVD-compliant MPEG-2 first. TMPGEnc, CCE, MainConcept are just a couple of examples of encoders that will take your AVI and convert to MPEG. Go to the guides section, and click on "AVI to DVD" in the conversion dropdownOriginally Posted by mlo356
If in doubt, Google it. -
i downloaded avi to dvd and when i went to convert, it wen from 230 mb to like 7 or 800 mb. i wanted to know is that normal? is it a way to make it about the same size?? TY
Yep, that is about normal. The reason is that for Xvid and divx you need to generally use 3-4x the bitrate of the AVI on the MPEG to retain a similar quality, resulting in the filesize of the MPEG also being rough 3-4x the AVI. You could make the MPEG the same size if you wished, but if you kept a DVD-compliant resolution I can almost guarantee it will look crap
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 17:36 -
mkv (x624 + 5.1 dts + ssa subs) to mp4 (x624 + 2ch aac + burned in subs)
By chameleon789 in forum Video ConversionReplies: 2Last Post: 22nd Jan 2008, 04:01 -
Creating my own subs for avi & editing subs of ogm & mkv
By retroborg in forum SubtitleReplies: 1Last Post: 1st Jan 2008, 15:33 -
What Tool: Type in subs while viewing subs from hardcoded video
By kpic in forum SubtitleReplies: 3Last Post: 6th Jun 2007, 20:29
