I have an ATI 550 Pro, and i had to capture a clip at HQ quality ( 8 Mb ) MPEG-2. the clip ran 53+ minutes in length, but power cinema decided to split it into two clips, the first file being 2 GB, and the second one being 1.16 GB. So, I used a program called CombiMovie to join the two clips. After joining them, I played back the .mpg file in windows media player, and it plays back just fine. So i used Tmpgenc dvd author 1.6, and created a DVD with a full working menu and chapters throughout the entire 53 minute clip. the only problem was, after i created the DVD, it will only play back the first portion of the MPEG movie, it repoerts back the movie length as being 33 minutes, which is the length of the first 2.0 GB file before i joined the two files. How do i fix this problem? I tried it again, using the same 53 minute file, but not before recreating it using Combimovie, but to no avail, same result, only 33 minutes is reported back as the movie length once i create the DVD. can anybody offer suggestions?
A penny saved is a waste of time. One in the hand is only worth 0.5 in the bush. A stitch in time saves nothing.
add both clips in tmpgenc dvd author. don't join with any other tool. or did you try it?
Originally Posted by BaldrickA penny saved is a waste of time. One in the hand is only worth 0.5 in the bush. A stitch in time saves nothing.
Originally Posted by guns1ingerA penny saved is a waste of time. One in the hand is only worth 0.5 in the bush. A stitch in time saves nothing.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Originally Posted by borax
"java.lang.OutOfMemoryError"
my system is an AMD64 2800+, ULI1569 chipset, 512 ddr400 ram, and about 300 gig of hardrive space, serial ATA..
anybody know how to get rid of this error?A penny saved is a waste of time. One in the hand is only worth 0.5 in the bush. A stitch in time saves nothing. -
Ask in the ProjextX forum: http://forum.dvbtechnics.info/forumdisplay.php?f=16 . Usually dvb.matt (writer of ProjectX) is very helpful and fast in solving that kind of errors.
It is a german forum, but you may post your question in english too.GUI for dvdauthor:
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 15:16 -
Joining 2 files together to burn 1 DVD
By glorybaron in forum Newbie / General discussionsReplies: 2Last Post: 31st Aug 2008, 04:20 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 22:00
