Hi all,
I got some chinese TV-clips in .RMVB- and .RM-format.
In order to put them on DVD, to make them watchable on TV, I tried to convert them to .MPG using EO-Video. In most cases (.RMVB) this works fine.
But for these .RM-Files EO-Video gets near the end of the conversion the message "Warning. Unexpected video stream end in source file. File may be corrupted". The output-mpg file (watched in Winamp and Mediaplayer) has complete sound and correct length, but shows only the start-frame.The corresponding Input-RM-files play well. I also tried ASF-AVI-RM-WMV-Repair on these files, which says, it has repaired, but the repeired file isn't convertable either.
Trying to produce only video (.AVI) with EO-Video results in error "Can't read frame" always at the same timestamp of source input very close to beginning (av. 65/100 sec).
Trying to produce only video (.MPG) EO-Video gets nor error, but no output is written.
So my questions are:
Is the input-file corrupt ?
Is there any chance to get this into .MPG-Format ?
Thanks in advance,
Delta
Partly solution found.
Mplayer and Mencoder didn't work.
But after I installed RealtimeSplitter on my system I was able to do the conversion (RM)VB -> MPEG via TMPGENC.
But there are still some problems: When using a SVCD as target format, I get the warning "GOP too long ..." After I ignored this I was able to biuld DVD structure with TMPG DVD-Author. But playing this DVD on my standalone player, every VOB derived from an RM-file freezes after 4-5 minutes.
So I tried the conversion (RM)VB -> MPEG with DVD as target format. Here I get no GOP-Warning. But the resulting DVD stiil freezes after 4-5 minutes when playing the VOBs derived from RM. Those VOBs from RMVB-files play fine.
Any suggestions are welcome !
Regards,
delta
How to convert to .mpg without failing?
By Grahamf in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 18:36 -
need to convert mpg to avchd
By mrgreaper in forum Video ConversionReplies: 5Last Post: 14th Aug 2009, 09:49 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47 -
convert .mov to .mpg
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 09:51
