  1. Hi, I have ATI AIW pro 128 32mb, and I can't configure the Virtual Dub with Win2K, don't appear the choose 352X240 and just appear the option YUV, when I was in WindowsME appear many options like YUY2 and others kinds, I need to capture in win2K because my VHS tapes have 1hour or more and in WindowsME I can't do that, Please someone have a suggestion to me please????
    Marcos
  2. I don't use the 128 AIW, but I can try to offer what I know:
    Win2k has this small problem of cutting access to the hardware directly if you use MS's WDM drivers for capturing - which is the case for my AIW 8MB Pro card. Because ATI did not write the proper drivers (I think) for Win2k, you can only capture using Software-based drivers. And the ones that you described are more hardware-based.
    In your case, you would need to set VirtualDub to enable multi-segment capturing and have each segment about 2000MB each to capture longer shows.
    I hope this is some help...
    Akito Tenkawa
