I am trying to transfer a vhs video casset to a dvd
I have a canopus twinpact 100, a MAC G5 and a VCR.
The VCR is connected to the canopus by rca jacks and the canopus is connected to the MAC by firewire.
I am using iMovie on the MAC to capture the video.
I have done this in the past. However this tape I just tried to digitize seems to be causing me problems. I suspect some sort of protection on this vhs casset (Macro media??) I don't know.
What happens is that the first few seconds of the begging of digitization are clear then the image gets very dark and stays that way.
So what do I need to do? Is this a common issue?
That is macrovision or some other type of copy protection. You will need something like a Sima "Copy This" box or TBC to go around this.
Depending on how much you are willing to spend, you may want to look at this:
Zorilla Video Filter -
What do you mean by a canopus twin pack 100? Acanopus avdc 100 will remove macrovision "noise" if you hold down the input selector button for 20+ seconds before starting movie. you only have to do this once unless you shut off the canopus box. Nyah Levi
http://www.canopus.us/US/products/TwinPact100/pm_TwinPact100.aspOriginally Posted by nelson133
Thanks for the tip.. I'm hoping it will work on the twinpact100.
Copy right protection on Glee?
By chiburu in forum Newbie / General discussionsReplies: 14Last Post: 24th Sep 2010, 10:47 -
Copy Protection
By Big Jake in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2010, 14:31 -
Rendition - New Copy Protection?
By funnel71 in forum DVD RippingReplies: 27Last Post: 27th Feb 2008, 05:37 -
CD copy protection
By KingSeti in forum Off topicReplies: 14Last Post: 26th Feb 2008, 12:01 -
Comcast and copy protection
By BobT in forum Capturing and VCRReplies: 9Last Post: 5th Sep 2007, 21:06
