i have tried the following as suggested by "bluez":
1. extract sound using vdub (save wav)
2. change length of sound (adjust to 25 fps pal from 23.976 ntsc film means you have to speed up the sound a little, approx. 95.90%) for example with cool edit
3. start tmpgenc, select 'do not frame rate conversion', use original divx as video source, resized wav as audio source, generate
The video is fine, but i cannot get the sound in sync
Please help me if there is any of you out there who have succesfully converted a ntsc-divx to pal, so that it can be viewed on a stand-alone dvd-player...
Since you speed up the sound anyway, use a Avisynth filter.
First decompress the audio. VirtualDub> video direct stream copy, audio full processing mode> PCM uncompressed. Save avi.
Create a Avisynth script
AVISource("c:\filname.avi")
AssumeFPS(25,sync_audio=true)
Load the .avs as videosource into your favorite encoder.
Image jerky after converting a DVD to MKV
By siocnarf in forum Video ConversionReplies: 2Last Post: 22nd Apr 2012, 15:14 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
DivX to DVD with FFMpegX - result jerky
By akulier in forum ffmpegX general discussionReplies: 5Last Post: 19th Feb 2008, 17:40 -
Philips DVP3040 DivX playback jerky
By mkgordon in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jan 2008, 16:35 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 09:32
