Results 1 to 30 of 33
  1. Am I the only one having problems with ripping "Hitch"? I'm using "Shrink" and Decrypter, but can't seem to get'r done. Anyone have any suggestions?
  2. Eh, what's the problem?
    -Yar, matey!-
  3. The problem is that, I can't get it to rip the movie. Using shrink, it starts analyzing, but it freezes up after about 14 sec.
  4. sounds like hitch has protection that shrink doesnt bypass. try dvdd or dvd43 and see if that works.
  5. "dvdd", do u mean decrypter?
    Apr 2005
    New York
    I had no problem when I used the latest version of DVD Decrypter and Shrink. Hitch has the copy protection where there are all sorts of intentional mastering errors , but Decrypter read through that. Now what I do is first rip it to the hard drive and THEN I use Shrink to back up from the files on my local drive. I hope this helps.
    Holmes
    Eliminate the impossible. Whatever remains, no matter how improbable must be the answer.
    S. Holmes
    Apr 2005
    New York
    Also let me add the disclaimer that burning copies of DVDS is really only defendable if you are making back ups of movies you already own. Along with Hitch I purchased Lois and Clark Season One, Kojak Season One, and Ed Wood, so I spent close to $150 for all of that. I would love to know how anyone can deny that we have a right to fair use when we spend like that. If the major companies want to curb copying may I suggest that they do one of the following:
    1) Include a second copy of each disc as a back up, not unlike getting back up copies of the coftware that comes with a fresh computer.
    2) Offer replacements for damaged disks at no cost and no postage as long as the original damaged disk is returned to the customer service department.
    Of course that won't happen because they want us to spend every dime they can squeeze out of us. How else do you explain things like a SPECIAL edition of every single movie that was just released a month before. At last count there were THREE different DVD offerings of The Exorcist.
    Holmes
    S. Holmes
  8. Sometimes it is not the softwre, your reader may not handle the induced errors as well as another might. If possible, switch to a different piece of hardware and you may find your problems clearing up. In my experience, what hardware may work for one disk with the induced errors, may not swork for a different disk, and vice versa. Nyah Levi
  9. The real issue is the recording artists and movie studios would like an automatic withdrawal to take place from our personal bank accounts every time we recall a favorite lyric from a song or line or scene from a movie . . . .
    Of course they think it is ok to charge multiple times for the same "artistic content" via rentals, new versions of releases, new media technology, tariffs on media "assumed" to be used for copying copyrighted material.
    I think these folks talk out of both sides of their faces and ends of their bodies . . . .
  10. Member tmac2085's Avatar
    Sep 2003
    yeah i've was trying all day burning Hitch. I finally got it with the file mode in DVD decrypter, and then used shrink, and burned. Works fine. btw, does anyone take stuff out of the dvd to use less space like bonus features and previews?
    Apr 2005
    New York
    Yes I tend to remove foreign language audio because i don't lsiten to it ant then I can up the compression ratio a bit so that I get better video quality.
    Holmes
    S. Holmes
  12. Member tmac2085's Avatar
    Sep 2003
    what do you use to take out stuff?
  13. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Titlesetblanker or Vobblanker
  14. Thankz ladies and gents for ur advice. I'll keep trying and let ya'll know the results. Thankz again for the help.
  15. I don't know if this will help but I had a similar problem with Dances With Wolves. I finally succeeded by playing the movie (for a minute or two) before each part of the backup process (rip with dvddecrypter, shrink with Shrink, burn with dvddecrypter). It seems to unlock something but I haven't been able to find out what. But, if it worked for me, maybe it will for you too. Good luck
  16. you could always try to remove the "hitch" movie,thus gaining even more space for quality veiwing,rather than that piece of shit movie.
    LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
  17. it's because it has the new Sony crc protection on it...the old dvd decryptor will come up with errors, but the new version will bypass the protection...
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    Hitch might be a shit movie - but it is Number 2 so far this year in gross $$ at the box office oddly enough (world wide)
    World Wide Box Office 2005 to june 12th .. in millions..
    1 Star Wars: Episode III - Revenge of the Sith $677.9
    2 Hitch $362.9
    3 Robots $240.1
    4 Constantine $229.5
    5 Howl's Moving Castle $218.4
    6 Kingdom of Heaven $204.3
    7 The Pacifier $184.5
    8 The Ring Two $155.7
    9 Madagascar $142.1
    10 The Interpreter $141.5
    note - several movies like Sin City are not in full world release yet and have not earned enough to get on the list ..
  19. theres no accounting for taste is there.
  20. Член BJ_M's Avatar
    Jul 2002
    Canada
    Howl's Moving Castle (Hauru no ugoku shiro) sure has done well
  21. Now if Disney will put it on more than 200 screens!
  22. Member
    May 2005
    Toronto
    hey I have a question about this movie, I used decrypter and shrink fine on this but when I burnt it the first time, the dvd-r could not be read in my dvd palyer or my computer , it just freezes, I burnt it a second time and that worked fine , but there are lots of glitches through out the movie. Does anyone know what this problem could be ?
  23. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds like crap media / bad burn to me ...
    If in doubt, Google it.
  24. Member
    May 2005
    Toronto
    hmm Im using Maxell DVD-r , I went through an entire spindle before with no problems, but this spindle has given me liek 3 crap cd's already and ive maybe only burnt 7 of them. Ill try burning some dvd-rs today, hopefully the problem dosent continue
  25. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    What's the MEDID ID on those MAXELL DVD-R? Download DVDINFO PRO or DVD IDENTIFIER to find the MEDIA ID.
  26. Member
    NYC
    I do only main movies unless its DVD-5
  27. Member
    NYC
    Holmes
    thanks Holmes,
    Thats the same technique I am normally using, but unfortunately I still unable to rip Hitch movie. Disc is brand new. No scratches or anything like that.
    I just tried newest DVDDecrypter v3.5.4.0 like you suggested but have no luck. Instead of failing on first VOB file, this time (with newest version) it fails at forth VOB.
    TIA
    taboo
  28. Member
    Jun 2005
    America The Beautiful
    Your computer has problems or your DVD is a bad/defective copy. Hitch rips flawlessly in ISO mode with the last release of DVDDecrypter.
    flonk!
  29. Member
    NYC
    thanks Mister Flonk-Flonk,
    Let me try ISO mode.
    Will I be able to burn it with DVD Shrink after all?
    TIA
    taboo
  30. Member
    Jun 2005
    If your copy of it isn't a defect and you can rip it, then yes, Shrink will do the job.
    flonk!
