Alright..I can't explain this one, so I'm hoping someone can.
I saw a cd the other day with multiple versions of WinXP on it and various utilities/etc. When looking at the properties of the cd it says 659mb is used up on the cd.
HOWEVER!, if you copy the contents of the cd to the hard drive and check the properties again...the file add up to over 3gb! I was attempting to slipstream SP2 and my SATA RAID drivers, but I couldn't get it back to cd because it was so huge!
I could understand if this was 3gb worth of text files and they were all zipped, but this cd shows no signs of the files being packed or zipped in any way...in fact, individually checking the properties of each folder on the cd will reveal that they are 400-500mb a peice.
any ideas?
Never come across a Windows XP CD with multiple versions plus the addition of various utilities. Its either the home edition or the Pro Edition. Something doesn't sound right here.Originally Posted by greymalkin
Is it actually a original Windows CD?
http://www.cdmediaworld.com/hardware/cdrom/cd_protections_dummy_files.shtmlOriginally Posted by greymalkin
vcd4ever. -
There was a disk, well 2 dvd's that had all the diffrent versions of windows on. Not what you would call legit in Mircrsofts eyes......
Not bothered by small problems...
Spend a night alone with a mosquito
Is their software for playing MP3/Audio files on a 4.3GB DVD in a CD player
By jbitakis in forum AudioReplies: 8Last Post: 26th Jan 2009, 01:04 -
AVI to DVD - Only 3Gb size
By Mutenroy in forum ffmpegX general discussionReplies: 3Last Post: 29th Mar 2008, 00:39 -
question about how to cut 1 minute out of 4.3GB DVD (no menus)
By jimdagys in forum EditingReplies: 20Last Post: 18th Nov 2007, 02:31 -
1.3GB DVD Help Camcorder
By Mark V in forum MacReplies: 8Last Post: 18th Sep 2007, 12:24 -
Converting AVI to DVD - Only 3Gb
By Mutenroy in forum ffmpegX general discussionReplies: 4Last Post: 2nd Aug 2007, 18:21
