Closed Thread
  1. Member tmac2085's Avatar
    Sep 2003
    i have a movie that i have been trying to burn for the past few hours but can't. and on the back of the case it says its copy protected. i used dvd decrypter to get the ISO. and now i have a MDS file and a RAR file containing the video_ts and the audio_ts and also has some sort of jacket_p folder too. and when i double click the RAR file Magic ISO comes up with the folders loaded. I know i need to shrink the RAR/ISO file since its 7.95 gb. But im not really sure on how to do that. I have never had this such of a hard time burning/copying a DVD. Please help. Thanks!
  2. You should probably just delete all of that stuff and re-rip the DVD with DVD Shrink. If you don't have access to the original DVD anymore, just mount the ISO to a virtual CD-ROM, and use DVD Shrink on it. Nero has a Virtual CD program in it as well as Alcohol and many other programs.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You should just be ripping the files (video_ts folder) straight to disc with decryptor...then use dvdshrink to open the files.
    Google is your Friend
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    SHould stick with one post for the same problem makes it alot easier to keep track of what people are telling you 8)
    https://www.videohelp.com/forum/viewtopic.php?t=271582
    Which is the same thing i told him on top of what what to do with his iso image
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    one thread is enough
