  1. Member thecrock's Avatar
    May 2005
    england
    I have a flipper disk of the wild bunch and i only want to keep the main movie and burn it to one dvd 5. I have ripped two iso files to my hard drive with dvd shrink. My question is how do i burn the two files to dvd so that they play as one movie? Any help is much appreciated.
    “He who makes a beast of himself gets rid of the pain of being a man.”
  2. You can do this using DVDshrink.
    Open each of the ISO images into DVDshrink - FILE, OPEN DISC IMAGE, then backup each of the images as a Hard Drive Folder. Name them Part 1 and Part 2.
    This will then give you 2 VIDEO_TS folders, now with DVDshrink in re-author mode just browse to the location of these 2 folders and open each one in turn and drag each Title to the DVD window on the left.
    Then backup the two titles as an ISO image and burn to disc with DVDdecrypter.
    Check out these guides, the first describes what you are trying to do with a flipper disc and the second describes the way I have told you, I'm sure one of these will help you.
    Take a look and see which is easiest for you.
    http://www.mrbass.org/dvdshrink/flipper/
    http://www.dvd-guides.com/content/view/46/59/
    After taking a second look at the guides I believe the first guide will probably do for what you want as it will prevent you from having to convert your ISO images to VIDEO_TS folders.
  3. Member thecrock's Avatar
    May 2005
    england
    Thanks HARRYSPADGE, i followed the first guide and everything worked perfectly, no problems whatsoever.
    CHEERS
