all,
i'm a newbie. can't seem to find the exact advice i need, so am posting this question. sorry if i'm threading old ground!
i want to capture from a vhs source, in avi format, at 720x576.
which capture card will allow me to do so?
also, will virtualdub be compatible with such a card? or what other software would you recommend. something that will allow me to capture in near lossless codecs like Huffyuv?
my system:
winXP (sp2)
athlon xp1800
512 mb ram
200 gb hard drive
thanks in advance.
Results 1 to 12 of 12
All avi capture cards (that I'm aware of) will capture Full D1.
Cheers, Jim
My DVDLab Guides -
I love these BEST questions --
the BEST would be (to capture in lossless or uncompressed) a DPS Perception card or Bluefish 444 or a decklink card or a AVID system"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
non of the above are compatible w/ virtualdub though ..
And I seriously doubt they are compatible with your budgetOriginally Posted by BJ_M
There are 10 kinds of people in this world. Those that understand binary... -
he wanted the best !
After you decide on a capture card, take a look at Virtual VCR for capturing.
Darryl -
ah BJ_M, the stuff you mention is within my reach ... but i'm not going to waste my money on hardware when i can spend it on booze! but next time i'll add "on a shoe-string budget" just in case!
reboot, bugster, dphirschler ... ta for your input, i will take on board what you've said. -
Why not just get a digital TV capture card with analogue in? they all handle 720 x 576 (to my knowledge, certainly the one I have does, and I have seen others) and if it only outputs Mpeg2 - re-encode the Mpeg2 stream to AVI? You get em from around $150 in my neck of the woods.
Originally Posted by manthing
yes booze is a far better thing to spend money on, i agree .. that and strippers and a little gambling .... the way life is meant to be lived .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
DV AVI vs TV card capture in AVI xvid
By fishywishy in forum Capturing and VCRReplies: 6Last Post: 29th Mar 2010, 17:54 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 14:12 -
Analog to Avi capture card
By ni-mh in forum Capturing and VCRReplies: 0Last Post: 25th Jul 2007, 17:16 -
720x576 avi files lose their aspect ratio when played on DVD player
By tzikeh in forum Authoring (DVD)Replies: 1Last Post: 24th May 2007, 02:47 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
