Hi,
Is there any software out there, that will, remove the voice from a small part of a DVD,but leave the music still playing.
What has happen is that a TV announcement has come in the middle of a film, I need to remove this.
Thanks,
Chris Sayer![]()
I use the analogX vocal remover, but I don't think it will help much in your case. It is based on the idea that vocals are recorded evenly on both channels of a stereo track, so by inverting the wave of one channel, and overlaying on the other, the vocals will be cancelled out. So long as that is the case, it works reasonably well. The catch is, if there is anything else that is the same on both channels (percussion etc) they will also be cancelled out. I have had some tracks reduced to little more than backing vocals because they had very little seperation in the recording.
To use it you would have to demux the audio, convert it to wav format, then load it up into your audio editor (that supports directx plugins) and process just that section, then reencode the audio and put it back. Is it really worth the effort ?Read my blog here.
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 17:00 -
Howdy,VHS to DVD and I want edit to get rid of the dross and add voice over
By rabbithutch in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2011, 17:12 -
Do do I keep the voice and soundeffects but strip out the music on a DVD?
By mbeaumont in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2010, 16:15 -
Voice-Over Popping in MPEG Video Wizard DVD
By cyberboy in forum AudioReplies: 4Last Post: 30th Aug 2008, 08:59 -
How Can I Separate DVD Music & Commentary's Voice?
By Aaron1927 in forum AudioReplies: 5Last Post: 10th Aug 2007, 17:28
