  1. Is it available to be downloaded for free?? PPl are selling it for 10 bucks on ebay, was wondering if i can get it for free.
    Also is it simple to use?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    No, it's not a free download. However there is a trial version you can use. I wouldn't buy it off ebay because they could be selling OEM versions of it that may not work. OEM versions usually only work with the drives it came with. If you want free burning software download DVD DECRYPTER while you can. You can burn ISO images on dvd by using DECRYPTER.
    USA
    I'm not aware of it ever being free. There may be some trial or crippled versions out there. Some versions are bundled with DVD burners. You want to be careful of the version offered. The ones with the burners are often OEM and may only work with the burner it was set up for. Also, if you have a newer burner, an old version may not recognize it.
    All in all, if you want it, go to the Nero's website and get the real version or there is probably a boxed version that would be OK if you know what you are buying, but probably not for $10.
