If I have a photo in a slideshow Timeline in Vegas...how would I animate for example snow falling on top of a photo? I have a still of people sitting in a yard playing in the snow and want to make it look like snow is falling during the slide.
Thanks everyone for your help!!!!!
crack open that manual and do the tuorials ..
just use one the noise textures and modify it for your own use ,,,
in fact "starry sky" is perfect for this ... just make the background transparent and drop on your top track .. add some 1 direction motion blur to texture and thats it for basic "blowing snow""Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
VAAST is a resource site for vegas things
http://www.vasst.com/login.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks BJ_M......!!!
I am evaluating Vegas and need to find out if will do certain things. I am evaluating Adobe and Sony. The Sony product seems to be more user friendly with good video and audio from I can tell. I will definitely read the manuals when I purchase.
Thanks again for your prompt response!!If you choose not to decide, you still have made a choice.
Neil Peart
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 08:23 -
Motion Animation for Creating Instructional Videos?
By Gromit137 in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2009, 01:02 -
animation to dvd
By J. Baker in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2007, 01:53 -
Cartoon Animation
By dbanga in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 11:46
