I've been using FCE HD for a couple of months. Though there is much I can still learn about the program, I've become proficient enough to perform the basic editing tasks I need to do.
How hard is it to migrate from FCE to the full FCP version? Is there a large learning curve? I am assuming that most of the basic functionality in FCE is essentially the same in FCP. Am I correct in assuming that the interface is basically the same in both programs with just enhanced capabilities in FCP?
I would like to begin using DVDSP. I can either purchase DVDSP alone and continue to use FCE HD. Or I can go all the way and just purchase Final Cut Studio and get the whole enchilada. The cost is not the limiting factor since I can qualify for the academic discount.
John
John,
You are correct in assuming that there is somewhat of
a learning curve, and depending on your ability to
get frustrated easy or not, and if you have the time,
that will determine your ability to grasp the program.
FCE is a stripped down version of FCP.
the diffrences are listed here:
http://www.dvcreators.net/discuss/showthread.php?t=1947
most current: http://www.eventdv.net/Articles/ReadArticle.aspx?ArticleID=9901
but for all inents, if you have a grasp on FCE, you can easily
grasp the basics of FCP quickly.
And while either program can work well with DVDSP,
you do get a better price break buying the whole studio,
instead of just 2 apps. Go for buying the whole
enchilada, if you can afford to do so."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Can I store captured video on a separate hard drive and still use FCP?
By birdfeeder in forum MacReplies: 2Last Post: 2nd May 2011, 00:33 -
Newb FCE Question
By Jralph in forum MacReplies: 3Last Post: 17th Apr 2009, 11:56 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
HDV export in FCE
By Vralteladden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2007, 17:41 -
chroma keying on FCE
By ednarophati in forum MacReplies: 3Last Post: 3rd Jul 2007, 21:02
