I have a big problem! My dvd player streches my movie both horizontaly and vertically. So when i encode to vcd, i have to choose 4:3 display, on the advanced tab,only then i get black boarders on both sides. But how can i get black borders vertically without uisng the clip filter( cause then i clip away the part i want to se!) So is it possible to add top\button boarders?
frotsen
Results 1 to 9 of 9
I am not sure, what your problem is. Simply tell us the resolution of the source. If it is a MPEG, you have to know the displayed aspect ratio.
My sources are 640*272 23.976 fps, i want to play it in widecreen. But when i encode it with 1:1 VGA and full screen (keep aspect ratio) Every thing looks perfect on my pc, but when i play it on my dvd player, the edges are cut of! Therefor i have to have a squeesed picture (horizantaly) in tmpgenc, which i onlly achive with 4:3 ont the source aspect ratio. Now the edges are not cut of, but top and bottom are cut of. So i'm wodering if it's possible squeesed the picture vertically?
frotsen -
Source avi 640x272. TMPG> source aspect ratio 1:1 VGA> video arrange method "full screen [keep aspect ratio]".
Target aspect ratio 4:3. This is the easiest way, but you can not see the entire picture on TV due to the TV overscan area. That's why I suggest to use the video arrange method "center[custom size]" 320x124. Target resolution 352x240, aspect ratio 4:3. The resize calculation I did with FitCD. -
Thanks! I bow beneath the wise Truman! while singing I'm not worthy, i'm not worthy!!
Yea I now, I'm weard. In my incanity of happynes i wrote that. Ok.... thanks for fixing my problems!
I have an AVI file but they are different sizes Truman so how will I know which one I need to put what Settings to resize it....??? As some of them if I use a Source Aspect Ratio of 1:1 and full screen I will not be able to see the subtitles.. so I followed your tip by using a Center custom and putting it as 320 x 220. By using this settings will I still be able to play it on my DVD player and see it on the TV set ?? So far most DVDs I have created have played but this anime Divx I got could see subtitles on the PC only under media player but when converted to VCD I could not see them as they were like at the bottom.. had to set my TV set to do a 16 X something then the subtitles are visible.. I would like to redo it into an MPEG file but not sure if this setting of 320 x 220 is possible while still at 1:1 ??
I calculate any resizing with FitCD. Center (custom size) defines the source aspect ratio.
For example 320x218, target resolution 352x240 (DAR 4:3).
__________________________________________________ _______
Merry Christmas. See you next year.
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 04:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 09:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 04:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 19:59 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 14:27
