I just got a Hauppauge WinTV-PVR-USB2. It comes with ULead DVD MovieFactory 3. When capturing from a analog camcorder, is it better to WinTV200 to record the signal as if it were a TV signal or use the Ulead and capture? Is there any difference?
Thanks.
Hi,
I can't imagine there would be. Your using the device to capture. The software should be immaterial. Why not experiment though with a few test subjects????
Kevin
(PS I can only really record with wintv2000 on my wintv pvr 250 and I get great caps)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Ulead sucks at capture. It's a decent enough beginners authoring program though.
You have to jump through hoops just to change channels...
Start with WinTV2k, and move up to better capture software when you're ready.Cheers, Jim
My DVDLab Guides
Record (capture?) directly to the pc...not to tape first
By bobogs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jun 2009, 06:55 -
Capture/Record XBOX360 HELP!
By dpunkz in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2008, 10:38 -
VGA Capture and record?
By shifterkart in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2008, 11:52 -
TV broadcasts to Record, Capture, and process, etc..
By vhelp in forum RestorationReplies: 2Last Post: 28th Dec 2007, 23:55 -
Record/capture webcam stream ?
By bat5hit in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2007, 17:33
