    Apr 2005
    United States of America
    Hello all,
    After some reasearch, I decided that the Hauppauge WinTV PVR 350 would be a very good card for me? Do you agree? Here are my needs for it: (NOTE: i can't use many of the All in wonders because i dont have an AGP Slot)
    -MPEG2/AVI Capture at full resolution 720x480
    - VERY GOOD QUALITY
    I know this one only captures MPEG, but thats ok. I plan to capture off of svideo from Dish network box.
  2. I have the PVR-250 and its great!
    Do use s-video, it will give give the best picture. I use an old SVHS camcorder to capture my home video. I set the capture the MAX MPEG2 bitrate. I then convert to Xvid to keep the quality and get smaller files.
    For the love of God, use hub/core labels on your Recordable Discs!
  3. If you don't need FM radio capture and TV out (from the PVR-350) then you can spend less and get a PVR-250. You might even consider the PVR-150 (which is replacing the 250) but a few people have problems with distorted audio. If you get a 150 be sure you can return it if you in case you run into that problem.
    Dec 2002
    I've got the 150 and am thrilled with it. I use the Canopus ADVC-100 for video that I need to edit and "play" wih a lot - but the Hauppauge is great for capture and burn. Usually I add a menu with MF4 and tell it not to re-encode it.
    3.141592653589793238462643383279502884197169399375 105820974944
  5. Member painkiller's Avatar
    Aug 2002
    Planet? What Planet?
    I have the 350, as well. I doubt you will be disappointed with it.
    I actually got into using the FM radio portion of it, too.
    On my cable system, they also distributed FM music stations too - just splitting the video coax and feeding the FM input side made for crystal clear reception.
    Very nice card.
    Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
