Trying to get less blockiness , I've tried SVCD 352x480 and the resulting file size of the MPG is the same !!!!
I've tried 4:3 and 1:1 aspect ratio (output video) in TMPGEnc.
Same thing on 352x480 vs. 352x240 MPEG1.
WHY ??????????????
Miguelo Perez
Argentina -
The size of the mpeg wont change until you change the bitrate....so try to increase it first to get less blockiness.
OK. But why ? Is there less information (pixels) in each frame/field ?
Tks.
Miguelo Perez
Argentina -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
this means that only certain amount of data (bitrate) is allowed PER SECOND. It doesn't matter the resolution, whether is's 720x480, or 100x100. Whatever amount of bitrate you choose will be destributed over that resolution, whatever it is.
So, obviously it makes sense that for higher resolutions, you should try to use higher bitrate (since there's more pixels to cover).
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56
