  1. Hi to all,
    How would I author a DVD with just chapter points and no menus if there is a guide on how to do this please point me in the right direction. What I want to do is skip the tv commercials by putting a chapter point just after it and using the next button to skip them.
    Thank you
    Dimoutlook
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Use TDA and you can edit out the tv ad's & add chapter points anywhere you want and then authour and/or burn with TDA or any dvd burning program.
    You can have main menu with or without chapter menu's or no menus at all, just drop it in and it starts playing.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Lab can do it.
    If your source is AVI, then DivxtoDVD creates a disk with no menus and 5 minute chapter stops
    Read my blog here.
  4. Thank you all for the quick answers will try the free one first ifoedit
    Dimoutlook
