I need to send a DVD to the USA, therefore I'd like to create some subs in English and insert them wthout re-authoring the whole thing (DVD is in Portuguese). Is there any good tool do to that? I know how to do it with Subtitle Workshop and DVD Architect, but then I'd have to re-author the whole stuff. Thanks in advance.
I doubt that there is an easier, faster and better way to do it than with Subtitle Workshop and DVD Architect.
https://www.videohelp.com/forum/viewtopic.php?t=267417
but it is probably easier to reauthor a new dvd. -
Thanks to you both. Ok, since some of the clips are in Brazilian Portuguese, I'm translating myself and making the subs in DVD Architect. I have already exported a **.sub file from DVDA (had a hard time figuring out how to do that since DVDA subs are Unicode, so I had to open Notepad and choose Save as, selecting AINSI - HOPE EVERYBODY GETS THIS TIP - this procedure makes DVDA subs compatible with Subtitle Workshop).
As Balrick said, it might be easier to author the DVD. No problem.
- So I would just like to know how to mux these files....VOB + the exported **.sub file. I've already tried IFoedit or Vobedit but I don't know how to do that. Any tips, please???
Thanks in advance
Nothing??
I mmight write a guide on how to do it with DVDA and DVD Shrink...Should I? All the other ways seem a bit more difficult.
Add subs to existing authored DVD/Keep original Menus?
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2012, 19:56 -
Yet again: how add .srt subs to .avi for burning on DVD?
By VenusAndMars in forum Authoring (DVD)Replies: 10Last Post: 17th Jan 2011, 02:34 -
use AviSynth script to add graphic idx/sub subs in DVD Flick?
By MilesAhead in forum SubtitleReplies: 7Last Post: 17th Dec 2009, 13:24 -
Add Subs to DvD With Menus
By zoranb in forum MacReplies: 0Last Post: 9th Nov 2007, 05:23 -
I need to locate subs and add them to a DVD
By renosgurl85 in forum SubtitleReplies: 5Last Post: 16th Sep 2007, 05:50
