I have an Xvid that I want to author into a dvd. It contains two audio stream and a .srt file. I've demux everything and used DVD Architect 3.0 to author it. The audio file and the .srt file loaded up without a problem. But when the video was loaded, only 4 second of the movie load. I've tried testing my other avi, and they all loaded up fine. I've also tried convtering the video to another format like .wmv and divx, but error says "bad frame". Any clue on how to fix or to make this movie to possible? Oh yea, I was thinking about converting the original video first to another format first then demux. But would this screw up the audio? b/c it has two switchable audio.
try scan the avi with virtualdub, under video->scan video stream for errors.
Suggestions for DVD authoring with multiple audio streams
By farmkid in forum Authoring (DVD)Replies: 11Last Post: 19th Sep 2011, 18:23 -
DVD Authoring software needed for multiple videos and .sup subtitles
By EpiMann in forum Authoring (DVD)Replies: 2Last Post: 20th Apr 2011, 15:08 -
DVD authoring from multiple sources?
By architectofpain in forum Authoring (DVD)Replies: 9Last Post: 25th Oct 2008, 00:34 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
Combining multiple Titles into 1 (re-authoring a dvd)
By Liquid Drum Theater in forum Authoring (DVD)Replies: 33Last Post: 6th Sep 2007, 02:00
