I get the following error whenever I try to burn the a cue file.
Invalid offset for index 3 of track 2.
I have burned several VCDs, but this was my first attempt with a menu. I tried following the "How To" for a still menu
but TSCV is not available for ver 0.71, I could only get the latest 0.84. I got as far as creating the menu(which was really easy), but when it went to burn I got that error. I tried CDRDAO directly just to ensure it was not a TSCV problem, but I received the same error.
Any inputs??
Did I miss setting an option? Unfortunately all the help files I have seen are based on 0.71, except Martini's.
are u useing a Gui or the HardWay...if not try the XDuplicator Gui its Easy and creates backups too
do a http://www.google.com search for it
I tried both ways(VCDEASY,TSCV, and commandline). Again as I said I never had problems until I used menus. I'm wondering if it's really a CDRDAO problem or a TSCV problem corrupting something.
Are you using really long file names or folders where the bin file is buried deep in many folders?
I had errors when I did that.
After I renamed the files to shorter names with no spaces it worked alot better in tsvc.
Not sure if this helps...but ttool told me that.
I dont use cdrao though I use fireburner to burn the bin files.
burn multiple dvds with original menus
By pins123 in forum DVD RippingReplies: 1Last Post: 26th May 2010, 16:31 -
How to burn multiple VIDEO_TS folders to one DVDR w/Menus/Chapters
By Iceman67 in forum MacReplies: 11Last Post: 23rd Jan 2010, 17:10 -
Error when trying to burn
By arose1179 in forum Newbie / General discussionsReplies: 6Last Post: 16th Oct 2008, 16:12 -
I/O Error in IMG Burn - Help!
By msdker in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2008, 23:11 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16
