  1. Member ChachiFace's Avatar
    NTSC Land
    Hi,
    When playing back a recorded/authored disc from the Pioneer DVD Recorder, DVR-220-S, does the disc (DVDR) default to a menu screen or does it just start playing the footage in order?
    I remember there being a recorder out there that did not default to the menu screen when first put in a player but rather started playing from the beginning and you had to press 'menu' on the remote to get to the remote.
    Thanks,
    Chachi
    Dec 2003
    Eugene, Oregon
    When you insert a DVD recorded on a Pioneer recorder, the first Title automatically starts play back. You must press the menu button to call up the menu.
