Advice on this would be appreciated! Want to upgrade our 4 yr old PC, that I now setup in our recroom, with a Capture type video card to capture TV, display on TV. Currently it has a 2001 ATI Rage Pro 2x card ($100 back then) that does this but in soso mpeg1 (w low frame rate) and a soso user screen that's not easy for family to use.
The Wishlist: 1) Allow display on TV & Monitor, 2) have remote control, 3) preferrable record in VCD format, at least a bit better than current ATI card.
The old PC is: Pent 733mhz, VIA 693 ATX Mboard, AGP 32bit 2x slot, 384 mb memory; Windows 98 (could re-image with WinXP if needed). Perhaps a used ATI All-in-Wonder or Nvidia card? (Newer the better if it could be compatible with a newer PC if this old one fails eventually). Any Idea's? Anyone selling?
Thanks again!
Don Fleming
Bellevue Wa.
Hi,
The hauppauge wintv pvr250 would work perfectly. Hardware mpeg recording only though - vcd, svcd, and dvd capturing with remote.
I had it running on a win 98 amd 800mhz pc. So it should do just fine on your unit. Excellent quality, in fact I took it out of that pc and put it in my newer Emachine I bought last fall.
The PVR-350 has video out, only mpeg-2 though, so you can't play your avi's on the computer and watch on the TV.
The PVR-500 is just a dual tuner card, no video out.
You would be better off with a PVR-250 and a newer video card with video out on it.Cheers, Jim
My DVDLab Guides -
Thanks Folks!
So, my plan is to leave the ATI Rage Pro AGP card in which gives me the TV-OUT hookup for viewing PC on TV. I will look at WIN-TV PCI cards but may lean towards ATI PCI cards for compatibitlity with my older ATI Video card(?). Thats assuming new ATI PCI TV card OK with 4 yr old ATI Rage AGP card. Cool that the newer PCI TV cards still work on 4+ yr old PC's (I know the AGP cards have changed, higher 4x speeds now and all).
I do have an AverMedia Ultra TV PCI card in newer Pent 2.8 PC that I could try in the Win98 PC. I've been pleased with the Avermedia card, does it all, nice remote, cost < $100 on sale.
Don F -
Capture cards have no basis on "compatibility" with video cards.
If you have video out on your ATI AGP card, get a PVR-150/250/350/500.
Both the retail and MCE versions will work in regular XP. Download all the software from www.hauppauge.com
BTW, the Win-TV cards are NOT the PVR cards. They're basically the same as your Avermedia.
The PVR series has hardware mpeg-2 encoding.
Your system is too slow to use the Avermedia or Win-TV card, as they rely on the CPU to do all the work. The PVR cards do not.Cheers, Jim
My DVDLab Guides
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
