Hi Folks ,
I'm using this program since version 0.83 and I'm happy with it. But since version 0.91 the menu of the final DVD want show. What do I wrong. Did I miss something during the updates ?
Maybe... But that is hard to judge from outside.
You may try the following:
1. Install GfD version 0.92 with a full install (or even the "beginners package")
2. Delete the Reg-Key:
HKEY_CURRENT_USER\Software\VB and VBA Program Settings\DVDAuthorGUI\Startup
This resets everything. After the next start of GfD you need to go to the settings and update all necessary path informations. Then try a simple project. If even that doesn't help, we should have a closer look to the problem (then I will probably need a project file, log file and a short stream from you).GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:00 -
Problem with GUI for dvdauthor
By DonStefano in forum Authoring (DVD)Replies: 12Last Post: 19th Feb 2009, 17:19 -
GUI for DVDAuthor
By netbuddy in forum Authoring (DVD)Replies: 35Last Post: 15th Nov 2007, 06:12 -
gui for dvdauthor HELP
By dontpanic in forum Authoring (DVD)Replies: 10Last Post: 4th Aug 2007, 07:47 -
GUI for DVDAuthor Question
By tygger in forum Authoring (DVD)Replies: 1Last Post: 22nd Jun 2007, 23:24
