We're after a 30" or 32" LCD TV for our reception area at work.
The spec we need is:-
- No side visible speakers (need them to be round the back built in)
- PC (laptop) input (vga)
- Built in TV tuner
- Wall mountable
All the ones we've looked at so far have got speakers on show (normally at the side).
thanks for any input
Try - www.avsforum.com
They can suggest a LCD that will have removable speakers or speakers under the screen.Project Digital: Eliminate All Physical Media is finally underway!
Buying advice - Should LCD TV or blu-ray DVD player have Wifi capability?
By coody in forum DVB / IPTVReplies: 2Last Post: 11th Dec 2010, 11:52 -
Need advice on buying 1st LCD TV
By majax79 in forum Off topicReplies: 12Last Post: 5th Nov 2007, 12:22 -
buying an LCD tv.......some noob questions
By efiste2 in forum DVB / IPTVReplies: 7Last Post: 14th Aug 2007, 03:20 -
Need advice for buying a new monitor
By doomdoomdoom in forum ComputerReplies: 26Last Post: 6th Aug 2007, 04:53 -
LCD TV's the whats what in buying
By CheifWigham in forum DVB / IPTVReplies: 0Last Post: 5th May 2007, 03:17
