I have been making Vcds using Tmpgenc and Goldwave for the audio for about 2 years and am about to graduate to Dvds.
I have been searching the guides and am looking for an opinion on the best way to deal with audio on dvds. I use Goldwave for wave audio to maximize the volume. Is there a procedure that will allow audio editing and result in audio and video being separate on the Dvd? Is it necessary to keep them separate?
I'm open to any suggestions.
A & V can be separate all the way until you have a finished DVD. In fact, unlike VCD/SVCD authoring apps, DVD authoring apps mostly wants separate audio and video streams. They get multiplexed into VOBs as part of the authoring stage.
/Mats -
I'm going to rephrase my question.
I've been using goldwave to improve the audio on vcd's (resample, increase volume, remove pop and click) and saving it as a wave file. Is there a tool or method that will allow me to improve (edit) ac3 and keep it as ac3 on the dvd?
Thanks -
No. AC3 has to be decoded to wav to be edited (like all compressed formats 99.99% of the times)
/Mats -
Thanks for the info.
It helps narrow my search through the guides.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author 3
By WHISPERS1944 in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2008, 04:56 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
