the source divx file doesn't have any problems...
when i converted to mpeg2 and burned onto a cheap cdr, about every 5 - 10 min, the audio goes out of sync with the video and then after about 1 min, they resync automatically...
would this be the cheap cdr's or would it be something i did with conversion? i used gigastorage cdr, and i used tmpgenc with the default svcdpal template at 1400kbps/224kbps
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
