Recently TMPGEnc DVD Author 1.6 started giving me this error:
Any ideas as to why & how to fix it??
Results 1 to 25 of 25
Father knows best.
Hi,
Check tmpgencs website.
Also try to reinstall it. That occasionally solve problems.
I tried uninstalling & reinstalling. no go
Also tried the repair option & no go.
Their website isnt very helpful either... unless you found something.Father knows best. -
I do not want to argue about this. It is simply an "other idea" that's all. Usualy if I have an error from a SW which I cannot solve or I don't understand, I simply change the SW and get the work done.
I am using Gui for dvdauthor and it is quite simple for my projects. -
I think TMPGEnc DVD Author is THE easiest and most reliable.I cannot help you solve the problem,but I'd like to say that I've never had any problems with it(Touch Wood)nor have many other people.I would'nt just scrap it and use some other software.Originally Posted by dudeman316
Easiest - maybe, most reliable - for me certainly not - I want subtitlesOriginally Posted by laspis59
Abond,I understand what you mean.When I say its reliable I just mean that it has never given me any errors.
Like I said though I dont think dudeman316 should not use it anymore just because of an unknown error.There IS a way to solve the problem.Maybe someone else has had the same problem and knows the answer,afterall the subject hasn't been on the site for long.
thanks everyone for trying. I am open for all sugestions & good software substitutes. thanks again all!
I was thinking registry too. You might try registry doctor. That's what I use. I think it has a free trial period.
http://www.registry-doctor.com/?page=buy -
You could try:
Click start ,Click Run,type regedit and search for HKEY_CURRENT_USER\Software\Pegasys Inc.
HKEY_LOCAL_MACHINE\SOFTWARE\Pegasys Inc.
HKEY_USERS\S-1-5-21-796845957-1123561945-725345543-1004\Software\Pegasys Inc.
and delete the registry keys
Thanks all... I will try this & report back when I get a chance. Thanks again
I tried deleting the registry keys no go? Do you think a clean reinstal of Win XP would fix this???
Yes i have & i think its somethings wrong with this install of windows, maybe a new install is indeed in order.
Are you turning off any programs before you try to author? If so, you may be turning off a program needed by DVD author.
What kind of file are you trying to author? Be sure it's a file acceptable by DVD author.Is it Friday yet? -
Did you install any new software or hardware?
edit:
I tried a google search and found the same question but no answers. -
1. You didn't say if it is all the files you try to author or only one ?
2. I have seen this error as recently as last night. For me it is caused by a bad file. Whenever I have had this problem it means a recode of the troublesome file(s) is needed. I have been able in my case to pin it down to a specific file by trying them in author mode one at a time until the error appears. I put that project on the side until I have more time and went on to author other projects with no problems.
3. That seems to be a error thrown up by most TMPGEnc programs on bad files with a specific type(s) of problem. I have seen same type error in DVD Author, TMPGEnc Plus & TMPGEnc 3.0 Xpress. Sometimes I just have to encode the problem file with something else such as CCE Basic which I also own. It doesn't happen often but can happen. It doesn't seem to mean a read error as in can't read the disk but rather that it can not read some kind of information in the file.
Good Luck
Please let us here at Videohelp know how you succeeded for future reference.
Cheers -
Hey Tboneit, I redid a file put it back in & that fixed it. Must have been a corrupt file.
Glad it worked.
And Thanks for saying so, it'll help others in teh future.
Cheers
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
. Unfortunately it doesn't help dudeman316.
