Hi,
does somebody knows what are the meaning of the "A-V:x.xxxx" stuff when encoding with an opened terminal window ? And between the brackets, the first number is the current average bitrate of the video, and the second the one of the audio, isn't?
And finally, a bug: my encoding frame rate is totally wrong. It's written 64fps, and I'm more around 10 or something like this. Does anybody has the same bug or knows what it is due to?
thanx a lot for the answers,
kaz
A-V:0.069 [1082:96]
The number after A-V is how off sync the audio & video are according to the encoder. I never even thought about the bracketed number. Look through the source for the bracketed number:
(mux_v->timer>1) ? (int)(mux_v->size/mux_v->timer/125) : 0,
(mux_a && mux_a->timer>1) ? (int)(mux_a->size/mux_a->timer/125) : 0
hope that paints a picture. It's a ratio of video to audio mux timers.
mencoder isn't infallible - I've seen it report fps values of 1000. If it produces unacceptable results look into the -opfs/fps flags.
X264 CLI Syntax Help
By Eva-Unit01 in forum DVD RippingReplies: 9Last Post: 2nd Dec 2011, 18:42 -
CLI of BDinfo??
By RogerTango in forum Blu-ray RippingReplies: 3Last Post: 15th Oct 2011, 03:13 -
x264 CLI
By zammil in forum Video ConversionReplies: 16Last Post: 22nd Jan 2011, 12:22 -
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 11:50 -
3.0.0024 CLI error
By casperinmd in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 2nd May 2009, 18:15
