Hello,
I've got problems with installing under Panter.
In the self installer dialog I locate mplayer, mencoder and mpeg2enc.
All files are in the same folder.
Then I type in my password and all tools will be installed.
Also mencoder will not be installed.
Can anyone please give me a hint, what I can do to find out what I'm doing wrong?
Thank you for answering.
Thomas
Hi,
I've had and still have the same problem. The mencoder that is within the archive that is mentioned in the ffmpegx startup-dialog seems to contain a different version.
MEncoder dev-CVS-050118-17:00-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build by major for ffmpegX http://homepage.mac.com/major4/
AltiVec found
CPU: PowerPC
After locating the files I get this error:##cp: /Library/Application Support/ffmpegX/mpeg2enc: No such file or directory
I then get this error:##/bin/sh: line 1: cd: /usr/local/share: No such file or directorysudo mkdir /usr/local/share
The installer finishes the installation. However, uppon the next start of ffmpex mencoder is NOT found again.
I looked at the two directories that I've created.
/usr/local/share contains- mplayer
/Library/Application\ Support/ffmpegX contains- mpeg2enc
- mplayer
- gocrfilter_en.sed
- vcdxgen
- subtitle2pgm
- mp2enc
- gocrfilter_nl.sed
- vcdxbuild
- gocrfilter_none.sed
- yuvscaler
- tcextract
- yuvdenoise
- gocrfilter_fr.sed
- gocr
- mencoder
Mencoder has been copied. For some reason it seems that it is not beiing recognized.
I and many others have had that problem for weeks if not months now.
Is there a link to a "working" version of mencoder? Or is there a new version of ffmpegx out?
I have tried to be as precise as possible to get a precise answer or some kind of help that will get this fine piece of software running again.
globo
http://prdownloads.sourceforge.net/mplayerosx/ffmpegXbinaries180105.zip
http://prdownloads.sourceforge.net/mplayerosx/ffmpegXbinaries230105.zip
which contains the file version mentionned by Major
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
The same OS installed on two disks
By Jomapil in forum ComputerReplies: 29Last Post: 4th Jun 2009, 15:35 -
Just installed and failed
By cantthinkofanickname in forum Newbie / General discussionsReplies: 12Last Post: 21st May 2008, 12:20 -
Just installed a Scythe Shuriken
By Video Head in forum Media Center PC / MediaCentersReplies: 14Last Post: 14th Feb 2008, 07:42 -
Why do programs need to be installed?
By Rudyard in forum ComputerReplies: 18Last Post: 18th Jun 2007, 09:00
