i am trying to convert a xvid movie with a size of 576x240 for the movie to a dvd. I have tried AVI2DVD and The FilmMachine but when i play the dvd on my tv the video is cropped. can anyone help me with this problem. thanks.
Results 1 to 10 of 10
Use fitcd to create an avisynth script that will resize and take into account overscan areas. Feed this script to an encoder and ecnode as DVD compliant. Author and burn.
Or live with it. It's natural, it's always been there, it's not a problem (unless you download anime with fix subs that have been put in the wrong place)Read my blog here.
i see the full video on my pc but when it goes on the tv some of ot is cropped.
Then jimmalenko's right and it's the TV's overscan that's responsible. On most standard interlaced TV sets, you'll lose 5-10% of the picture to the overscan. If you don't like that, then take guns1inger's advice and use FitCD to add black around your videos to take the overscan into account.
Thought it might be overscan ...
Bear in mind that when you add black borders to suit the overscan on this TV, the next TV you get might have more/less overscan, so you'll either see a black border around it or some more will be cropped. That's just the way it goes, unfortunately ...
If in doubt, Google it. -
All TVs does thia ll the time, so you aren't missing out on anything you would have seen anyway. All commercial DVDs have video in the overscan area, so you have been missing this all along - has it adversly affected your viewing ?
Personally, I never bother resizing with borders for overscan - it just never seemed worth the effort.Read my blog here.
Hi-
i tried fitcd and i played it on my tv and it looks atreched and is still cropped.
Then you didn't use it correctly. You didn't say if you were PAL or NTSC. For NTSC:
LanczosResize(688,340)
AddBorders(16,70,16,70)
For PAL:
LanczosResize(688,408)
AddBorders(16,84,16,84)
That adds 16 pixels (2 blocks) to the sides. Different TV sets have different amounts of overscan, but 16 pixels should work for many. That's also with the ITU box checked, encoding for 16:9 (Anamorphic). Your Source (if AVI) is 1:1 Monitor, and I choose Anamorphic DVD Destination, although it might be argued that non-Anamorphic is the way to go.
Jim made a good point there. I used to make all these SVCDs with black around the outsides for my old interlaced TV set. My current widescreen HDTV doesn't have any overscan, and the black shows now.
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 16:05 -
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 17:05 -
DVD to avi(Xvid) - size problem
By skipadipadoo in forum DVD RippingReplies: 4Last Post: 9th Mar 2009, 09:07 -
Xvid Encode by File Size Problem
By hech54 in forum Video ConversionReplies: 5Last Post: 1st Jul 2008, 11:45 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 17:12
