compression ratio is at 73.7%, is that compressing the movie too much that it will look like garbage when burnt?
What We Do In Life, Echoes In Eternity....
I have DVD's that have been compressed down to as low as 60-65% and in my opinion the image quality is still acceptable,
I've done a bit of testing with my system and I find it quite difficult to notice any concernable difference from the original.
I'm very fussy about picture quality and I do have a fairly large TV (36") and I am quite happy with the quality I get from shrink.
Many people swear by DVDrebuilder but I've read mixed reviews about it, I guess the only way you'll know for sure is to write it to DVD/RW first as a test and see if you are happy with it, after all you are the one who will be watching it.
PS: I'm sure other people will tell you that it's too much compression, but as I said you should try it for yourself, nobody can really give you a right or wrong answer ! -
This Question is asked here over and over again, and along with the "what is the best" one is pretty pointless. No one can make that decision for you, test it on your equipment and see what you think. Everybody will have a different opinion, everyone has different standards.
I have compressed somethings to 55% and been happy and others I have pitched. It also depends on the quality of the source, which varies.
Nyah Levi -
Why not get couple of rw discs and try it? If you don't like the result, erase it and nothing is lost.
For some reason I actually never even thought of using one of my 10 rw discs. See this is why I love this site. Someone always recommeds somthing that is very simple and just overlooked.
Thanks guysWhat We Do In Life, Echoes In Eternity.... -
I did my version of Excalibur using the previous version of shrink and was not very happy at all. Unless it has been re-released, it was a pretty average transfer to begin with, and the grain and smoke play havoc with the encoder. I may try again some day, perhaps.
Read my blog here.
thanks
Need help with compression
By dfreeman1971 in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2010, 02:18 -
Better Compression?
By anirban in forum Video ConversionReplies: 20Last Post: 5th Oct 2008, 18:19 -
more compression?
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 15:22 -
compression
By m-man in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2007, 13:18 -
Compression
By Martig in forum Video ConversionReplies: 2Last Post: 25th May 2007, 22:17
