Results 1 to 10 of 10
  1. I've been using Nero Vision Express 3 quite happily until. last weekend, now i'm getting this error when i try to burn anything to DVD or when i try and access the edit menu screen. i have the latest versions also.
    error message:
    'OS: Windows XP Professional, SP1
    CPU: GenuineIntel, Intel Pentium 4, MMX @ 0 MHz
    Application data:
    VmVyc2lvbjogVVVKZFExQlRWbHRFVFVOSFF5c29PU2M1QndBNk pUOCt
    MVzk3WjJOck1DRWpQeU1rTTBGeGVIQjBaWE01DQpJbWFnZUJhc 2U6ID
    A2 ... etc etc'
    i really dont have a clue why this started happening. can anyone help
    thanks
  2. Just contact Nero for support.They authored the program so they should find the solution to your problem.Use Nero Info Tool to generate a log of your PC's setup and send it to them for analysis.
    Or use different software,Nero Vision Express is buggy and constantly crashes.
  3. Member pbhalerao's Avatar
    I wish you all the best; but I would not count on that.
    What major change has happened to your system in the last week or so? Any new software installed? Has any Windows Automatic Updates been loaded? Maybe some virus?
    You could try a system restore to one or two weeks ago and check. Check for spyware, etc.
    *** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
  4. thanks.
    i did a system restore but to no avail. i may need to go back a few weeks as suggested.
    what is the next best software I could use. I really liked Nero because it converted NTSC to Pal and it had a good menu creating system. Is there something out there that can offer me the same benefits?
    Humour
    You can download the file from
    http://ww2.nero.com/enu/Patch_for_NVE3.html
    It will fix your problem.
    JarJar
  6. Originally Posted by jarjar
    JarJar
    i'll try that when i get home, thanks
    Humour
  7. Originally Posted by Cruiser
    thanks.
    Try TMPGEnc DVD Author for making DVD's and VCDEasy for making VCD's they are both top notch software and crush Nero Vision Express
  8. Member INFRATOM's Avatar
    Try reinstalling Nero, First uninstall all Nero clean registry .. becarefull search for every entry on ahead or nero and delete it. Then reinstall Nero. The registry Part is long and could be risky if you have never done these things.
  9. There is a Nero cleanup tool that you can download from the ahead site. It takes out all the registry settings and is perfect for doing a clean install
  10. the patch seems to have worked
    thanks everyone
    Humour
