I've been trying to convert several DVDs to SVCD but have encountered the same problem with all attempts, namely that the last 5-10 minutes of video go missing. The audio is fine but the picture just freezes.
My method is to extract the film as a single VOB using 0SEx and then to use the SVCD ffmpeg preset with the settings as standard apart from unchecking Author as SVCD (XA.img) and selecting 5:1 for the audio channels (which doesn't work but I'm not particularly bothered).
The problem occurs whether I divide the film into 2 or 3 discs.
I'm running OS X 10.3.9.
Any advice as to what the solution might be ?
Are you using "Decode with Quicktime" with the "SVCD ffmpeg" preset?
Please also note that SVCD must use mp2 audio, stereo only.
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17
