Hello,
I vainly tried to find something in the forum:
Is it possible, to cut/edit elementary streams in Mpeg Video Wizard?
Or is that only possible in Cuttermaran, at least the fast and easy way...
I know - more or less - how to edit programme streams.
So does anybody know?
Thanks.
Results 1 to 10 of 10
yes you can .. same as program streams..
But in the Input-Monitor the audio is not played, when adding the video elementary-stream. So how do I make Wizard "get my meaning"?
Tell you the truth, I did not try yet since I could not imagine, how Wizard would cut the correct places... -
elementary stream video only - no audio
if you have two elementary streams (video and audio) , mux them together and do you editing and then demux
to cut the correct places - is up to you"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks, I guessed that - now I am sure!
Very fast answer...
It would have been nice to have the possibility. Sometimes I want to change the sample rate of a video file, afterwards use it in DVD-lab Pro to author. For both operations you need them demuxed (DVD-Lab demuxes, of course, but for sample rate change...s.a.)
So if I have to change the sample rate of an mpeg, I would go:
1. Demux
2. Change sample-rate
3. Mux
4. Cut in Wizard
5. Demux (again)
6. Author
If I cut first and change the sample rate later, I sometimes get a/v-synch-problems, the other way around - in 9 cases out of 10 - I don't. -
sample rate ? you mean bitrate don't you ?
i.e. re-encode"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
No, sample-rate, but I was not precise: I meant the sample-rate of the audio-stream of the video-file. Sorry.
That is: .mp2 with 224 bps/44100 kHz to .mp2 with 224 bps/48000 kHz.
(for example)
Just encode to elementary streams.
Cut in Cuttermaran.
Load into DVDLab.
3 steps, instead of 6.
Better yet, cut in virtualdubmod, frameserve to encode, author.
Still 3 steps, but faster because you're not encoding the portions you're going to cut anyhow.Cheers, Jim
My DVDLab Guides
Cropping Ability with Womble MPEG Video Wizard DVD
By montgal in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 22:11 -
Womble video wizard mpeg dvd
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:47 -
Frameserving Womble Mpeg Video Wizard
By tmw in forum Video ConversionReplies: 13Last Post: 1st Nov 2008, 08:53 -
Womble MPEG Video Wizard destroys audio?!
By noemi7 in forum EditingReplies: 3Last Post: 16th Jun 2008, 10:18 -
settings for Womble MPEG Video Wizard DVD
By Vril-ya in forum EditingReplies: 0Last Post: 20th May 2008, 19:18
