Results 1 to 15 of 15
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hey please help, wat do i do, i need to burn a disc urgently. please help, thanks
    Wow! You got shocks, pegs... LUCKY!
    Apr 2003
    Maryland
    Help !!!!!! My crystal ball is not working!!!!
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    Excuse me? um i really need help to get my burner up becuase i need to burn a disk. i dont knwo wat other information to give... thanks.
  4. Maybe it would be a good idea if you give us a little more information....
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    well, i tried to burn a disk, ISO -> DVD with DVDDecrypter, and it said that NO drive was detected. then i go to device manager, and there are exclamation marks on my 2 CD drives (my burner drive included) and my 2 image drives. and now i dont knwo wat to do to burn a DVD. thanks
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I think it may be a driver problem. Try either:
    Restrating your PC
    Using your Win XP CD to re-install the driver from Control Panel (where you see the exclamation marks) double click on that, go to the driver tab, and update or re-install the driver.
  7. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    yeah i thoguth it would be a driver prob, too but i cant find any online, the restart thing didnt work, im gonna try that the XP cd thing, thanks that is if i can find my Win XP CD :P
  8. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    but wait a sec, if my disk drive is not working, wat good will the CD do?
  9. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Sorry, i think that skipped my mind
    Try this approach:
    Disconnect the cable of your drives, switch PC on, shut down again, connect the cables back on, and hopefully, when you start your pc again, the drives should be auto-dectected by Win XP.
  10. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    well my drives are internal, how do i disconnect their cables? thanks
  11. Member thevoelk's Avatar
    Sep 2004
    Forest Hill, MD
    Windows has the problem with the drive, not DO. Boot to your CD. If you're getting a "Device Cannot Start (Code 10/19)" search google for "Delete Upper and Lower Filters".
  12. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    im sorry i cant say that i understand what you mean , what is DO? secondly, how do i boot my CD, if the drive is not working?, and how would i get the error DEVOCE CAN NOT START? thanks
  13. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    By opening your towercase. Disconnect the IDE cables (the grey one connected to the CD/DVD drives)
  14. Member thevoelk's Avatar
    Sep 2004
    Forest Hill, MD
    I meant DOS, my keyboard sticks. The error will be inDevice Manager, right click on My Computer and go to Properties-->Hardware-->Device Manager. The drives should be listed with an exclamation point over them. Double click on the drive and it should say something similar. Search google for the error code, it will take you to a microsoft support page with a knowledge base article. You will have to edit the registry, be careful. Most likely your recording software screwed something up.
  15. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    actually i made it more complicated than it had to be. i simply did a system restore and all was back to normal
    i would like to thank you all for answering to this post so quickly, i really appreciate it, thanks
