When I burn my SVCD the sound, picture, and subs are all messed up.
Here's the info on my rmvb, plz what frame rate should I use to convert it to SVCD.
General file properties :
Maximum bitrate : 900000 bits/s
Average bitrate : 416190 bits/s
Maximum packet size : 1342 bytes
Average packet size : 713 bytes
Duration : 4379506 ms ( 01:12:59.506 )
Prebuffering : 24000 ms ( 00:00:24.000 )
Index section offset : 0xDE5AF0Fh
Data section offset : 0x3F4h
Number of streams : 3
Flags properties :
Flags : 9
Download allowed : yes
Record allowed: yes
Perfect play : no
Stream specific information :
Stream number : 0
Maximum bitrate : 64082 bits/s
Average bitrate : 64082 bits/s
Maximum packet size : 930 bytes
Average packet size : 930 bytes
Time offset : 0 ms ( 00:00:00.0 )
Prebuffering : 1857 ms ( 00:00:01.857 )
Duration : 4380212 ms ( 01:13:00.212 )
Stream name : Audio Stream
MIME type : audio/x-pn-realaudio
Codec name : COOK - 24
Channels : 2
Frequency : 44100 Hz
Stream number : 1
Maximum bitrate : 835918 bits/s
Average bitrate : 352108 bits/s
Average packet size : 684 bytes
Stream name : Video Stream
MIME type : video/x-pn-realvideo
Video resolution : 592x336
Frame rate : 24 fps
Stream number : 2
Maximum bitrate : 0 bits/s
Average bitrate : 0 bits/s
Maximum packet size : 0 bytes
Average packet size : 0 bytes
Prebuffering : 0 ms ( 00:00:00.0 )
Duration : 0 ms ( 00:00:00.0 )
Stream name :
MIME type : logical-fileinfo
ASMRuleBook : #($Bandwidth >= 0),Stream0Bandwidth = 64082, Stream1Bandwidth = 355918;
Audiences : Easy RealMedia Tool's Audience;
audioMode : music
Description : This File is Created by Easy RealMedia Tools@!
Generated By : Easy RealMedia Tools V1.8x
videoMode : normal
1. Where do you live? You should use the frame rate used in your country (but I always use NTSC if the source is NTSC 'cause I have multi-standard TV and player).
Maybe you have used a format that it's not supported (NTSC 480x480@29,97fps, PAL 480x576@25fps). I really don't know about NTSC film (23,97, that it's the frame rate of your source file) 'cause it doesn't exist in the MPEG specs.
xVid4PSP and RMVB
By kumar66 in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2009, 19:10 -
rmvb help
By aimbdd in forum ffmpegX general discussionReplies: 4Last Post: 7th Aug 2008, 19:22 -
RMVB to MP4
By carloaccount in forum Video ConversionReplies: 1Last Post: 18th May 2008, 06:43 -
Help on RMVB
By JohnConstantine in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 08:30 -
RMVB
By magius in forum AudioReplies: 4Last Post: 7th Jan 2008, 09:26
