I have an audigy 2 oem sb0240 sound card and the newest drivers (SBA2_PCWDRV_LB_1_84_55-R1.exe) i try to install says theres no audigy 2 sound card installed,i e-mailed creative and they said "OEM products are not supported under the Retail driver download".
Anybody else with this same model oem audigy 2 have the same problem?I just want to know if its just my oem sound card being affected.
In case anybody has the same problem i have found the fix,what you do is search google for this item(ctcomp.exe) and extract the newest creative lab drivers into a folder with winrar or winzip and then open ctcomp.exe and point it to the driver folder you just created.
After the driver is patched then go into the driver folder and click on the setup.exe and install away.I think,therefore i am a hamster. -
there are set of real good drivers around for Audigy1-4
http://www.kxproject.com/ or
http://www.driverheaven.net/showpost.php?p=618748&postcount=101
give them a try, too! -
Thanks for the links,i now have a audigy2@audigy4 card
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 11th Dec 2010, 23:25 -
Still having driver problems with windows 7
By intheory in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2010, 18:18 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 21:45 -
Help With DVD Driver? Firmware? unknown burning problems..
By spongecake in forum Newbie / General discussionsReplies: 7Last Post: 16th Jun 2008, 16:17 -
Audigy Vista Alchemy fiasco...
By ofbarea in forum ComputerReplies: 1Last Post: 3rd Jul 2007, 08:51
