I don't know if this applies to any particular codec...But when i have a problem that i can't find a solution to I try to think in a stupid way to figure out the problem
Split up movies usually have the same codec and settings...So instead of virtualdub trying to decode and then recode them into one AVI just let virtualdub take the direct stream and just combine it with out trying to decode and recode them.
Under the "Video" Menu click on "Direct Stream Copy". "Frame Rate" and Select Range should be the only 2 options left available above "Direct Stream Copy". Open and append the movies and save as usual/
I just tried 3 different movies and it worked fine. It only took about 2 to 3 minutes per movie. Same quality and everything.. If anyone else can try it and let me know their results please post here.
L8r OnE
Results 1 to 1 of 1
combining two .sub and .avi files into one
By agassi in forum Video ConversionReplies: 1Last Post: 8th Jul 2010, 16:59 -
Combining avi files in virtualdub mod
By buckethead in forum EditingReplies: 2Last Post: 11th Aug 2009, 20:22 -
Error in Vdubmod when combining srt and avi
By majax79 in forum SubtitleReplies: 4Last Post: 19th Apr 2008, 04:33 -
Mpg to fixed avi size.
By jjulio1 in forum Video ConversionReplies: 12Last Post: 8th Mar 2008, 15:59 -
HP Photosmart D5160: ink stains inside printer?
By stantheman1976 in forum Newbie / General discussionsReplies: 3Last Post: 27th Feb 2008, 19:47
